Sign in to follow this
new Aristo replacement 4 axle trucks
I see that there's a new 4 axle Aristo replacement truck available. The store listing I looked at says it's for the U25B/ FAs/ and RS3. Has anyone seen this new truck in person yet? I would guess it's the same inside as the original?
I may need to get a few of these for Aristo engines I have.  I am new to G and have a few questions on installing the Bachmans.
As I understand it the older Aristos will need an A frame installed to make this work as the earlier ones used extended axles to fit into side bearings to hold the blocks in.
The Bachman blocks don't have the protruding axles and must be mounted with an A frame
So how do I  install an A frame if needed?
I read an article on it but it seemed a bit complicated
I would appreciate any info on this!\
Thanks!
