RHands
Slow running Lionel 4-4-2
I am running a Lionel 4-4--2 and it is slow and weak.  Other engies move right along especially when I run both sides a MRC dual transformer to the track.
Is this typical?   'Any possibility I have locomotive that needs AC power?  rhands
No...Lionel large scale locomotives use DC power only...it's stamped on the bottom cover of drive block. Try cleaning the drive wheels with a q-tip dipped in alcohol, lacquer thinner or some suitable solvent. And don't forget the backside of drive wheels where carbon power pickup brushes rub.
Thanks for the info, indeed it is so marked on the engine.  Found out last night with the dual MRC transformer connected speed was sluggish, but when I added an LGB transformer (small grey unit); (3 units total) it took off like a scalded hound, well maybe a beagle tracking a rabbit.  Very acceptable but I am not sure about the consequences of hooking 3 transformers to the track.  I believe my wiring is adequate, it is 2 16 or 18 ga wire running to each rail (4 per track) and a 20 foot run.   I have cleaned and physically buffed the tires with a Dremel fine grit buffing wheel    If it would help I could measure track voltage with and without load.   Also could probably get the amperage under load.  I would like to figure out wha'sup rather than throwing transformers at it.
