Choochoowilly Posted May 25, 2019 Share Posted May 25, 2019 Been working on my mason bogie tender and cab while waiting on styrene tube and sheets from plastruct. Got the tender fitted to the cab and both sanded and primed, using aircraft aluminum prime as it was a very fine spray and was sandable + seemed to fill the voids in well. Got the goal old eztec load cut and fitted and covered on top of the original one with real Pennsylvania coal glued on with tile bond III. Added Crip for coal as per drawings I have been working off of. Do think it a little strange that the cage meant to hold the wood in place was also surrounded by sheeting for coal + the fact the engine has a wood burning stack but was coal fired. Must be one of those either or engines. Next on my list will be to paint it with final colors and add detail parts and then on to the chassis. More to follow Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted May 26, 2019 Share Posted May 26, 2019 willy, looks great, please keep us posted. LiG Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted June 9, 2019 Author Share Posted June 9, 2019 Got the cab and tender painted and lettered, color matches my passenger cars which this engine will pull, now on to the boiler and chassis Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted July 31, 2019 Author Share Posted July 31, 2019 Got the cab, tender, cowcatcher mounting plate and cylinders done, the cab and tender are screw to the deck plate for fitting purposes and will be removed for painting later. Now time to plan articulation, which should be fun Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted August 1, 2019 Share Posted August 1, 2019 willy, if it's any help: Accucraft's Mason is actually pivoted on both the drivers and the tender wheels, unlike the swing as on an articulated locomotive. The pic shows the pivot on the drive is between the first and second drivers. LiG Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted August 1, 2019 Author Share Posted August 1, 2019 Nick, Beautiful engine, yours? Mine will as also just have to dream up a pivot for it and it will mount in the center of the upper top where the 6 holes are just above the center driver.Thanks for the pictures, if you have any that are from the top/side and show the pivot point that might be helpful, Bill Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted August 1, 2019 Share Posted August 1, 2019 Bill, yes it is mine. It's a live steamer so I would have to do quite a bit if dismantling to get to the top of the frame, sorry. LiG Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted August 1, 2019 Author Share Posted August 1, 2019 3 hours ago, Screwy Nick said: Bill, yes it is mine. It's a live steamer so I would have to do quite a bit if dismantling to get to the top of the frame, sorry. LiG Lucky dude, no I wouldn't want you to do that, maybe a picture from the side between the chassis and the top, I am so envious!!! Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted August 2, 2019 Share Posted August 2, 2019 Bill, best I could get, I hope these help. Pretty busy down there but in the lower one can see the post where the drivers are attached. LiG Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted August 2, 2019 Author Share Posted August 2, 2019 Nick, you are so right, kind of busy down there but at least I got to see a work of art up close, beautiful engine, Thanks, Bill Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted August 2, 2019 Share Posted August 2, 2019 Bill, yes Accucraft out did themselves with this beautiful creation. Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted August 11, 2019 Author Share Posted August 11, 2019 Moving along with the Mason Bogie bash, got the dome bases finished and sent to the paint shop, also fitted the boiler running board support and adjusted and glued the boiler upper fire box Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted August 12, 2019 Share Posted August 12, 2019 Bill, great progress, keep it up. LiG Quote Link to comment Share on other sites More sharing options...
Choochoowilly Posted August 17, 2019 Author Share Posted August 17, 2019 Further progress on the mason bogie, boiler painted using cab light green and missed with silver over spray and the fire box I added rivets and colored both it and the smoke box with a dark gray metallic graphite. Pretty much most of the detailed fitting is done allowing a better look at the articulation suspension. which will be next along with the coloring of the running boards. Domes are done and screwed to the boiler with single 8/32 screw and leaving only the bell to be built and fitted to the top of the boiler. More to come, Bill Quote Link to comment Share on other sites More sharing options...
