Rayman4449
MTH DCS Remote & TIU firmware: v6.10 (Current version)
Updated: 11/1/17
Wanted to share that the latest version of the DCS remote and TIU firmware is now available.  (Updates are provided by MTH at no cost.)
How to check the DCS version that you have loaded to Remote & TIU:  (You have to check each separately)
- Remote:  Turn on remote and confirm the x.xx number you see when it first powers up (4.10, 4.20, 5.00, 6.00, 6.10 as examples)
- TIU:  Using the remote and with TIU powered up, go to MENU -> SYSTEM -> TIU SETUP -> TIU VERSION
This version is important as it is required in order to operate the new WiFi module (WIU) that is about to be released that allows you to control your trains with the Android/iOS app.
Download: (DCS v6.10 for TIU & Remote)
       - From MTH: DCS v6.10  (See instructions below on steps to download and install from MTH)
       - Or direct .Zip file here:  DCS 6.10.zip
(**Note: You do not need to change or upload anything to your engines.  This is software only for the Remote and TIU.**))
Version 6.10 New Features
  • Added Record/Playback In Super Mode
  • Required For Wi-Fi DCS Premium App (Build 2.0.1 iOS and 2.0.2 Android)
Version 6.10 Resolved Issues
  • Addressed numerous fixes resolved with release of DCS WiFi Premium App (Build 2.0.1 iOS and 2.0.2 Android)
Also please Note:  To load this latest version of DCS you MUST use the new DCS Loader Program version 5.00:
Download: (DCS Consumer Loader Program v5.00 for the PC/Computer)
        - From MTH here: DCS Consumer Loader Program - ver 5.0   (See instructions below on steps to download from MTH)
        - Or direct .Zip file from here: MTH DCS Consumer Loader v5.00.zip
*You will need to update the DCS Consumer Loader program to use the Remote & TIU files.*
Instructions on how to download and install the DCS Consumer Loader program direct from MTH:
DCS Consumer Loader Program version 5.00 for Windows PC:  (This is the software you install and run on your Windows PC to perform the TIU and Remote firmware/software updates)
   -  Visit www.protosound2.com
   -  Download the DCS Consumer Loader Program Version 5.00 by clicking the 'Download Now!' link.  (*Click for example photo*)
   -  Fill out the required info then select 'Go to Download Software Page'.   (*Click for example photo*)
   -  On the DCS Software Version 5.00 link either left click to download and note where the files are saved OR right-click and select 'Saved linked content as' and save to where you want.  (*Click for example photo*)  (Right click menus will vary based on Internet browser used)
   -  You then have file "V5.0.0.exe".  (This is a file that can self-extract, you do not need winzip or any other program to extract the files)
   -  Use 'My Computer' or 'This PC' on your desktop or use Windows file explorer to go to where the file was saved.
   -  Left-click the "V5.0.0.exe" file (which starts the self-extractor)
   -  Then select the 'Browse' button and save to 'Desktop' so it's easy to find, then click 'Ok' then 'Unzip'   (*Click for example photo*)
   -  You now have two files "Setup.exe" and "MTH DCS Consumer Loader V5.0.0.msi".
   -  Go to where they are saved and Left click the "Setup.exe" file to start the install process and complete.  (MTH recommends un-installing older versions of the loader first)
   -  Left click the "DCS Consumer Loader" shortcut on your Desktop
   -  You will then see this screen where you can select icons to either load to TIU or load to remote.  Click the appropriate icon and follow the instructions.   (*Click for example photo*)
            - Note where you saved your DCS TIU and Remote files from the steps below.
             -  *For Reference* DCS Consumer Loader thread:  www.gscaletrainforum.com/index.php?/topic/694-mth-dcs-consumer-loader-v500-current-version/
You will also need:
DCS version 6.00 for the TIU and Remote:  (These are the DCS data files that the Consumer Loader Program uses to update your TIU and Remote)
   -  Download the DCS Version 6.00 by clicking the 'Download Now!' link.  (*Click for example photo*)
   -  On the DCS Software Version 6.00 link either left click to download and note where the files are saved OR right-click and select 'Saved linked content as' and save to where you want.  (*Click for example photo*)  (Right click menus will vary based on Internet browser used)
   -  You then have file "DCS6_00.exe".  (This is a file that can self-extract, you do not need winzip or any other program to extract the files)
   -  Left-click the DCS6_00.exe file (which starts the self-extractor)
   -  You now have three files.  Two are the key ones you need "tiu6p00.Dcst" & "remote6p00.Dcsr"  to use with DCS Loader program.  These files cannot be used on their own.
For instructions on how to upgrade the TIU and Remote software see below or my website:
www.rayman4449.com/DCS_Tips.htm#DCS_Software_and_Upgrade_TIU_Remote  (also see my website for info and photos for needed cables, additional information and troubleshooting.)
Step 1: Updating the TIU
**When updating to a different version of DCS software in your TIU and remote, you should always start by updating the TIU first.**
  • Connect your TIU to the computer using either the 9 pin serial or USB cable (Your computer can already be booted up)
  • Plug the 3.5mm stereo audio cable ends into the TIU's "Proto-Dispatch" & "Proto-cast" ports
  • Connect the power supply to the Fixed 1 input port OR connect the Aux power supply to the Aux power port on the TIU
  • Start the DCS Loader program
  • Close out of any unnecessary programs or applications and do not use the computer while the update is in progress
  • Click the load software to TIU Icon
  • Carefully follow the instructions on the screen. (it will instruct you to connect the serial cable and 3.5mm audio cables)
  • Then select the "*.DCSt" file (example: "tiu5p0.DCSt")
  • The update process should start and will tell you when you are finished
Step 2: Updating the Remote
Once you have updated the TIU software to the version you are wanting to use, then update the remote.
  • BE SURE TO REMOVE the 3.5mm stereo audio cable ends from the TIU's "Proto-Dispatch" & "Proto-cast" ports
  • Start the DCS Loader 2.xx program
  • Ensure your remote has good batteries and test it by turning it on.
  • Ensure the remote is off before you get started
  • Connect the remote to the TIU with the 4-pin narrow phone cable.  (Be sure to plug the remote into the Remote input port NOT the AIU port!!!)
  • Click the load software to Remote Icon
  • Carefully follow the instructions on the screen. (it will instruct you to connect the serial cable and remote cord)
    • NOTE:  When instructed to press the power button on the remote, the remote should remain off.  If the remote powers up, it's not detecting it's plugged into the TIU.
                   See below steps for troubleshooting.
  • Then select the "*.DCSr" file (example: "remote5p0.DCSr")
  • Follow the instructions on the screen
  • The update process should start and will tell you when you are finished.
