enginear joe Posted June 3, 2016 Share Posted June 3, 2016 Working on some LGB G scale tank cars.... The white Olin was built by someone else with USA trucks The CSX has modified LGB trucks and USA wheels The Hooker has the new RB Kadee trucks on her Quote Link to comment Share on other sites More sharing options...
enginear joe Posted August 12, 2016 Author Share Posted August 12, 2016 I have several different sets of trucks lying around and decided to try them as well. I got a set of wheels in. They are bigger and have a better looking profile. I have not tested them yet to see how they will perform on my Aristo track and switches. I forget where I just got them from? I believe it was from here: http://www.thetraindepartment.com/wheels-truescale/ I still wanted to use them and installed a set of bearings inside of the Aristo RB modern trucks first. I'm after rolling stock that will look good, and perform the best. Having real bearings inside the trucks should help out the engines on my long trains over grades in the backyard. I need to re-install the RB caps with some type of shims as the axle ends are thinner. It appears that the KD medium offset couplers will do the job easier too. Quote Link to comment Share on other sites More sharing options...
enginear joe Posted August 12, 2016 Author Share Posted August 12, 2016 Here she is finished. I still need to test her in a train. Quote Link to comment Share on other sites More sharing options...
