November 6, 201412 yr Hi,http://www.youtube.com/watch?v=FbRY8xNNTl8&list=UUs-1J5encyIiXg398nG3bMw Greets from Germany Jan
January 22, 201511 yr Author Hi,http://www.youtube.com/watch?v=FbRY8xNNTl8&list=UUs-1J5encyIiXg398nG3bMw Greets from Germany Jan Don't know how I missed this video link? I like your work! The track profile looks very good. The rear pilot on that CNW unit looks great! I need to detail my stuff like that soon!
January 22, 201511 yr Thank You.At the moment I'm building this CNW unit for DPU transport. http://www.google.de/imgres?imgurl=http%3A%2F%2Ftrn.trains.com%2F~%2Fmedia%2Fimages%2Frailroad-reference%2Fask-trains%2Fmay-2011%2Ftrn-at0511_06.jpg%253Fh%253D412%2526la%253Den%2526mw%253D600%2526w%253D600&imgrefurl=http%3A%2F%2Ftrn.trains.com%2Frailroads%2Fask-trains%2F2011%2F05%2Fdpu-rear-markers&h=412&w=600&tbnid=LPSR01Dkl017jM%3A&zoom=1&docid=cvH8cjKh8XhMWM&ei=kFZJVJ3NJ8T1OPnvgNgB&tbm=isch&client=firefox-a&iact=rc&uact=3&dur=2101&page=4&start=57&ndsp=19&ved=0CIACEK0DMEgThis is a dummy unit as a helper at the end of the train.I know this is not the right rail company.I know you like modern railway, try it.I build the electronic into the rear truck, which is empty.
January 31, 201511 yr So almost ready, where are the 48 'Johnstown America Corp Bethgon Coalporters - CNW?I'm waiting for
January 31, 201511 yr Author Well I have that engine already.... I did get a FRED from Ozark, but it seems too big at 1/29.... http://www.ozarkminiatures.com/scripts/prodView.asp?idproduct=914 Hmmm, maybe it's not as big as I thought it was?
March 1, 201511 yr Prime beacon... https://www.youtube.com/watch?v=a9V93fIl1Gk&list=UUs-1J5encyIiXg398nG3bMw
March 3, 201511 yr Author That is great work on that beacon! I'd like to see it at night. How do you think it looks? Realistic? I'm going to try it too. Thank you for sharing. I got that fitting. The inside farrel is shaped a little differently. I'd better try again. Did you cut it into two pieces?
March 3, 201511 yr Thank you all, In the dark it looks good, the video is too bad, I try it again later. This is a Swagelok fitting VA 10mm, very expensive.The rings are honed flat.The hood is made of glass and red on the inside, with dip paint for light bulbs.For ATSF yellow.The electronik comes with 6 volts. I take a DC / DC converter, 1 amp.The bulbs are replaced with LEDs 5 volts, built-in resistorThe speed is adjustable via potentiometer.Works like the original.I have found a video, not mine.Good Luck. https://www.youtube.com/watch?v=QPl0dmbGoR4
March 26, 201511 yr Small UpdateFor this ( or that ? ) Dummy I built a voltage buffer with 8 Greencaps.The capacity is 5 F, voltage 2.5 volts. The capacitors are low impedance.This is important. The capacitors support the voltage regulator for lighting.The capacitors are in series, maximum voltage 20 volts.That works 18 sec. Without power from the rail.
February 13, 201610 yr Author I just searched for a long time to find these posts from Dash 8. I finally remembered to get a MTH EOT flasher. I knew there was a post on installing it here. Now, I'm reminded that I forgot about the Beacon!! I have too much stuff going on to even remember what I want to do next! I wish I had stayed strictly in G scale. Everything I buy in O scale needs work or attention to run on my 2 rails.
March 10, 201610 yr Message. I needed to thank you for this good read!! I certainly enjoyed every little bit of it. I've got you bookmarked to check out new stuff you post
December 20, 20169 yr Author I've moved the G scale down to the floor level. I have O scale 2 rail on the bench work. I have since just added a 3 rail Highline in O scale for guests. I didn't know if I should post about other scales???
December 21, 20169 yr I agree as it does look good! Nice & smooth. So does that now officially make you a Hi-Railer??
