jerrybaffetto Posted May 21, 2022 Share Posted May 21, 2022 good morning everyone, new engine block with Mabuchi motors, pitch choice from 80mm and up maximum voltage 24 volts possible constructions on request Quote Link to comment Share on other sites More sharing options...
jerrybaffetto Posted May 22, 2022 Author Share Posted May 22, 2022 After a few hours of planning, I managed to make the two axles independent in this configuration the minimum wheelbase is 62 mm you can get an even closer pitch but with a fixed engine block, not articulated same thing you can have articulated motor block with pitch on request some pictures are attached Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted May 22, 2022 Share Posted May 22, 2022 Since the wheel spacing can be adjustable, with the correct side frame look like they would be great for trolley cars. Quote Link to comment Share on other sites More sharing options...
jerrybaffetto Posted May 22, 2022 Author Share Posted May 22, 2022 hi Nick! actually they could be useful for a lot of models my goal is to make them as versatile as possible hehe I will keep you updated! Quote Link to comment Share on other sites More sharing options...
Screwy Nick Posted May 22, 2022 Share Posted May 22, 2022 Will you also be offering different wheel diameter?? Or possibly spoked wheels?? Quote Link to comment Share on other sites More sharing options...
jerrybaffetto Posted May 22, 2022 Author Share Posted May 22, 2022 hi Nick certainly, wheels can be made in different sizes you can also get spoked wheels but they are laser cut in metal and then they are edged with stainless steel rim. it would be possible to make them in the foundry and then machine them on the lathe but I have to get in important order for this type of wheels and all of the same type Quote Link to comment Share on other sites More sharing options...
jerrybaffetto Posted May 24, 2022 Author Share Posted May 24, 2022 hello everyone here are the first tests of the engine blocks everything is ok for now now we are waiting for the electric motors, worm screws and gears! (what you see are only tests, the final models will be perfect in every part of printing) Quote Link to comment Share on other sites More sharing options...
