enginear joe Posted June 22, 2015 Share Posted June 22, 2015 I ran in the basement for about ten years and never had a problem with the stock MTH electric couplers. Moving outside, running long trains up steeper climbs, I've had a few times where the stock couplers have failed. It started with one older diesel engine's electric rear coupler breaking and not staying closed reliably. I had another steam engine where the coupler would dip, and release the train. I believe that was caused by how long the whole coupler hangs off the back of the tender unsupported properly. It screws onto a bracket that is mounted by the far end making it hang off the back of the tender too far unsupported properly. I think it should be supported nearer to the center of the assembly, where it should pivot from. I believe a KD coupler box would help resolve that problem as it screws on nearer to the center of the coupler's swing. I would hate to loose the ability to drop off cars when I want. So I'm looking at the KD servo coupler for a solution. I'm wondering if anyone has tried them with a MTH Protosound 2 or 3 board to see if they'll work?? http://www.remoteuncoupling.com/ Quote Link to comment Share on other sites More sharing options...
Rayman4449 Posted June 22, 2015 Share Posted June 22, 2015 I haven't tried the KD version but I would assume they should work just fine. Regarding the coupler dipping, I've never had a problem with that on any One Gauge model even pulling 100ft trains and would think that has a correctable issue. I'm guessing either the posts or post holes are messed up in some way. Quote Link to comment Share on other sites More sharing options...
Chuck Posted June 22, 2015 Share Posted June 22, 2015 Ray watched as my USA Big Boy w/ PS2 and ProtoCoupler on the rear pulled 100' of coal hoppers for 8 hours with never a release. Of course all the cars have Kadee's Quote Link to comment Share on other sites More sharing options...
